michaelT23
- April 29, 2023
- Kingman Arizona
- 1996 Ford Explorer Sport
Hello. New here to the forum. I'm having a new serious issue with my 1996 Ford Explorer Sport 5spd 2wd. This vehicle has been in my life since 98. It has over 200,000 miles on it and has never had a serious mechanical issue. 2 weeks ago as I was turning on a side street I hit a pothole that jolted my car roughly. Soon after I noticed my explorer was not running pushed in the clutch pedal and it would rotate the engine but wouldn't start. Pulled of the street and started to investigate and found it blew fuse number 19. I replaced it with a new 25 amp fuse and it fired right up with no problems.
So now to the present day. I was four blocks from my house driving on a decent road and accelerating from a red light it stopped running pulled off the road and looked at fuse 19. It was blown again. So I replaced it again and I was off and running for about 1500 feet and during upshifting it blew the fuse again. Replaced it, pushed down the clutch pedal and turned the key and it blew as soon as it hit the run position. Ran out of fuses so had to get towed home.
At home started investigating. Looked at wiring diagrams, checked relays, ground connections. All looks good. Wiring has never been altered and nothing added. I bought more fuses and unplugged harness to coil pack and turned key and blew fuse. Replaced fuse and unplugged PCM harness and still blew the fuse. Unplugged the radio noise suppressor and still blew the fuse. I'm stumped?
Does anyone have any other ideas? Clutch interlock switch, column mounted ignition switch? HELP PLEASE.
