jazzkeys
- January 19, 2012
- The OC, SoCal
- 1996 Explorer XLT 4.0l V6
Howdy y'all,
Check Engine was on and the code is P0171. FoMoCo published TSB 04-17-4 about which I found a reference:
http://www.aa1car.com/library/ford_lean_codes.htm
I cleaned the MAF sensor with Radio Shack spray solvent though it wasn't really dirty. Also checked the sensor signal at idle and it's within normal range at 1.71VDC.
Replaced PCV valve and checked for intake manifold leaks visually using the cigar-smoke (yuck) test by removing the PCV tube and blowing smoke into the intake manifold through a 3/8" ID vinyl tube from HD. No visible leak. Turned off Check Engine using my code reader.
I've driven a few miles locally so checked for a pending P0171. No DTC yet, but haven't really fixed anything so I'm expecting that it'll return. The code reader showed that evap and catalyst monitors aren't ready, but that might be because I haven't driven far since clearing the P0171.
Bi-annual smog check here in SoCal is due in a few days but this chump is stumped. Any ideas? Thanks much.
