mustangfan35
- June 28, 2012
I Recently bought a 1997 Ford Explorer Xlt they said it was stuck in 4 Low I figured easy fix but I was wrong I've tried everything to fix it I've run codes and the DTC codes are 1824 1804 I've tested the switch on the dash it tested good I've took the battery cable of and tool motor off and turn manually still didn't change a thing I've also took the electric clutch wires apart that didn't change anything the front wheels are lock in and I don't know how to get them out my dad tried the brown wire mod trick and he said it disengaged the front wheels but it's in 2 low now so how do I fix the problem
