1997 Explorer overhead console temperature sensor | Ford Explorer Forums
allmyEXes
No. Alabama USA
1997 Blue Ex 4.0 SOHC
Callsign
KAGG 3611 (CB)
Can someone tell me where the external temp sensor for the overhead console is located on the 1995 t0 2001 Explorers?
An oldie from here: Ford Explorer Overhead Console Installation
specifically: The temperature sensor located near the front driver side near the radiator. It is 2"-3" long and about as thick as a cigar. It will have 2 wires hanging out the back.
Open the driver side headlight flap under the hood look down
If you need a pic ill take one for you
I'm not being sarcastic !
I believe you. I'm going to remove a sensor from a JY vehicle next time that I go there. Thanks y'all.
@donalds Is the sensor sort of under the headlight next to the antilock brakes harness/connector?
Yes on mine its under the driver head light
im quite sure mine is no longer in the stock spot, as it hangs down below in the fenderwell now, i see it once in a while but never knew what it was :banghead:
Anyone else have their temp reading off a bit? Mine always seems to be showing at least 3F colder than actual temp. This is not something that's changed/degraded recently, has done this from new AFAIK.
mine seems to be somewhat accurate? it hasnt been off more than 2 usually, so nothing much imo. then again, mine isnt in the right place anyways
Yes
A two degree swing
