ddaytona1
- May 13, 2011
- New Jersey
- 1997 Sport Vermillion
I'm getting a lound clunking in my '97 sport. 178K miles, with a remanufactured transfer case installed at 80Kmiles. The lound clunking sounds like it's coming right under the drivers seat. It occurs frequently/continually between 20 and 30 mph. then over 50 mph a little less frequent.
Reading through some similar threads, I changed the front Drive shaft u-joint and CV joint, and lubricated the slip yoke, changed the U-joint at the front of the rear drive shaft.
I can take the rear drive shaft and at the front U joint move it up and down and detect some play where the drive shaft connects to the transfer case. I initally thought it was a bad u-joint, but after replacing it, the play is stll there
I removed the front drive shaft toatally and still get that clunk at 20 - 30 mph. Is that the shift points?
So,the only thing left is the transfer case. What do you think?
