1998 Explorer 5.0 “Restoration2021” project | Ford Explorer Forums
SuperGordo
Las Vegas, NV
2022 Explorer ST
Hi everyone. It’s been awhile since I’ve been on here. Sold my 2000 explorer in 2014. But October 1st I picked up a 98 with a 5.0. 2wd, and a 3.73 T-loc rear for $500. The poor truck was a real mess. I live in Las Vegas so luckily there was no rust. Worst that happens here is the paint gets burned off. But the last owner or two showed the EX no love at all. I’m building this truck up for my oldest daughter who just had a baby and needs something bigger that her 98 Lincoln Mark 8.
First thing it needed was to replace the PATS module and new keys.
I replaced the fuel pump and filter, I removed all of the interior. I threw out the carpet it was so nasty. Pulled better carpet from the junk yard and scrubbed and pressure washed that. I pulled some decent cloth seat covers from the yard as well. The original leather is ruined. Everything inside was really really dirty. I recovered the headliner. A good buddy of mine loves to clean stuff and he went about sanitizing all the interior plastics. He’s done a fantastic job. The plastics look about as new as they can for their age.
Once I got it running it ran rough, and wouldn’t idle unless the MAF was unplugged. Did some digging and found that the fuse for the oxygen sensors was blown. Replaced that and she idled pretty nice. But had a touch of a misfire you could hear from the exhaust pipe. At this point it’s worth noting that there were clearly a boat load of vacuum leaks on and around the plenum. So we decided to pull the plenum and freshen up as much as we can. All the hoses under the plenum were a hodgepodge of whatever someone could find. So all that has to go. Replaced the pcv with a motor craft unit. Also put a new pcv grommet in. The original one was hard as a rock. The spark plugs were just horrible. Plug wires original 1998. The AC system had no r134 in it, so living in Vegas it’s getting complete replacement. The next step was to remove the AC box from the engine compartment. I installed a new evaporator for good measure. While that’s out I’m doing the valve seals and the valve cover gaskets. Some of the valve cover bolts were already loose. Removed them with my fingers. Luckily there is no sludge on the heads or rockers. Not bad for 253,000 miles. I put a bore scope in the cylinders and there is still cross hatch on the cylinder walls. So once the valve seal job is done and the tune up complete I believe this will run very nicely. I have a new set of fuel injectors going in as well.
For the small things and the details. I replaced the third brake light. Did all the lift support shocks, rear glass hinges. New speakers. New grill and front Ford emblem. New fog light assemblies. Found nicer bumper trim at the junk yard. Picked up some 15x7 1989 Ranger wheels. They need a good cleaning, but I think they’ll be nice. I’m sure I’m forgetting something.
Things I haven’t gotten to yet are the upper control arms, lower ball joints, new shocks, rear wheel bearings and diff service. And whatever else I come across.
A1BEDD23-BAE4-4838-8059-1DBDA504491B.jpeg 11A14CC2-BCE1-46FA-A36E-EBD0243F09A3.jpeg EE5FEE59-0EBE-4C55-BE16-D8AE67A9CCD5.jpeg 184666A8-9C8A-4791-9B14-DDECCC7BA216.jpeg 9EF45F33-32A4-4886-BF4B-5BE5871DB4FF.jpeg 71CA40A7-84B8-4EAA-AB73-CF6DA8A69607.jpeg EE0454FC-EE17-4D00-8D4A-58663C340520.jpeg 0928CFEB-3890-4C0C-9EBE-7BEF500BC572.jpeg 8A38E00F-A21D-46A6-A7C0-82DC1898C3A1.jpeg 75190742-42C4-49CA-8F1E-4008B1E63910.jpeg 59610459-CD8F-4C6A-AEA9-6D0E2F23F991.jpeg 8BC4CC81-F9D4-4AB2-A280-A81154F9FEA5.jpeg 60029872-5D2B-4A60-8A6C-E4A31F733B3E.jpeg 9E391E0C-C51B-4427-9AB3-A2E55F7A2D2A.jpeg FE4E41EC-9B45-4A14-8C61-ED72368B95B8.jpeg 19F4528F-B95E-47E2-9CC4-93A11B72878D.jpeg 3E02172F-FB02-4C8A-8F4D-41BF67B6E671.jpeg BBCA5C03-05AA-49E5-8604-51955ACE7661.jpeg 25981ADD-4FB8-4645-9CEE-7F9221D5B084.jpeg 94E53665-669A-42C8-9FE9-FBF98AF76626.jpeg
Finished the passenger side valve seals yesterday. The old girl got every Pennie’s worth from these ones. But I’m very happy looking inside the engine and the valve cover. No sludge of any kind. Which is surprising due to the apparent lack of care and maintenance. Let’s see if I can get the other side done today.
Did you check the blend door while you had the dash out?
Also, great job on the new headliner material install.... what kind of adhesive did you use?
EDIT: My dumb sounding question was based on the assumption that the demand for a special headliner adhesive didn't meet a high enough "demand" criteria to produce it rather to relay on various other adhesives out there.
Thanks! 4 cans of 3M high strength spray adhesive. Then needed a 5th can which I had to get from a different store. The 5th can was 3m headliner adhesive. Seemed similar to me. All worked nicely.
Today we did all the prep work to get to the drivers side valve seals. Need to pick a day to actually do the seals. But soon. The Drivers side is as clean as the passenger side under the valve cover. Which is nice.
91D95EF0-B5DF-4F8C-906C-F9B4133EEDB1.jpeg AE713258-8BCC-4475-BDA7-8AA6EB7A00F0.jpeg
Soon as the valve seals are finished and buttoned up I have to redo all the vacuum lines and PCV hoses that are under and around the plenum. The last owner used every imaginable thing he could find to repair stuff. The PCV lines are far from correct. So I've been using SEARCH here to work out the correct routing. I'm reposting some pics from previous threads in case someone needs the info and they wind up on this thread. Here is the part number for the entire PCV hose assembly if someone needs it.
PCV Valve - Ford (XL2Z-6C324-AA)​
5.0pcv.jpg 5e7dc349ea5abb87dfac9875d3c621ca.jpg 56E088DE-1855-4A35-AF17-ABD8404E0A41.jpeg
Another vote for basic 3M high-strength spray adhesive. The old fabric pulled off the compressed foam panel with a little care, and the new similar knit fabric from the fabric store went on fine. It has been holding up great for many years on my 95 Sport. (Pun intended)
Finished installing the valve seals today. The picture below is one of the old seals next to one of the new ones. The difference is obvious. I'm also going to replace the thermostat and the housing. It's a mess.
