Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
- Forums
- Generation Specific Forums
- 1995 - 2001 Explorer Ranger Merc. 2nd Generation
- Stock 1995 - 2001 Explorers
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
1998 Explorer 5.0 “Restoration2021” project
- Thread starter SuperGordo
- Start date
Add an avatar, upload photo attachments, and more!.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
Thanks Donalds, We will get this one done! Too close to stop! can't wait!Keep it up
- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Fair enough. I need to hit the yard for one of the plastic parts that holds the condenser to the radiator. So ill get the o rings from the fitting.
While there look for a V6 Explorer, and buy the bracket that holds the bottom of the condenser. That is much better than the V8 mounting onto the radiator. I haven't gotten one yet but the two V8 radiators I've changed in the last 18 months tell me I should have done it sooner. I have a SOHC 99 also, so I know how easy that was to R&R those parts before.
- June 17, 2004
- Knoxville, TN
That's great, it helps to not be so worried about going too far to start with. I have lots of parts to build 3-4 of the 4R, one a close ratio with the AODE sun gear/shell etc, for my 92 Lincoln.Also, as far as the drill sizes go for the Jmod on a truck VB. You simply use the same size the Jerry 101 article states. Ive Jmodded plenty F150s, the truck VB has a couple different springs inside that vary from passenger cars, but that doesn’t affect the JMod.
What do you know of the 6R80? I learned just enough to know I want to swap one behind my best project Explorer, a 337 later. I thought the 10 speed was most of the same trans, with changes needed to gain four gears from the same basic guts. A member on the Corral thinks they are all different internally. I don't want things more complicated, but I'm open to learning.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
i'll look for the bracket!While there look for a V6 Explorer, and buy the bracket that holds the bottom of the condenser. That is much better than the V8 mounting onto the radiator. I haven't gotten one yet but the two V8 radiators I've changed in the last 18 months tell me I should have done it sooner. I have a SOHC 99 also, so I know how easy that was to R&R those parts before.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
Don't have much experience with those at this time. As they hit a certain age they all come to me. But at this point I'm not sure the expense of the trans and a controller accounts for the cost of swapping one of those trans. But in the end it's up to you and what you want..That's great, it helps to not be so worried about going too far to start with. I have lots of parts to build 3-4 of the 4R, one a close ratio with the AODE sun gear/shell etc, for my 92 Lincoln.
- June 17, 2004
- Knoxville, TN
Gotcha. The six ratios are great for a wider speed band with big power, the 1st is 4.17:1, and the rest are fairly close after 2nd. With decent power, the 3.73's and 4R run out of rpm in 3rd gear. The 6R will demand a big R&P change, 3.08 is my plan. The cost will be at least $4k by my guessing at costs, for many things required to do it.Don't have much experience with those at this time. As they hit a certain age they all come to me. But at this point I'm not sure the expense of the trans and a controller accounts for the cost of swapping one of those trans. But in the end it's up to you and what you want..
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
I know some people don't like the big 6 speed plus trannys. They describe them as "hunting for gears" all the time. But it's certainly up to the owner. If it makes you happy, do it!Gotcha. The six ratios are great for a wider speed band with big power, the 1st is 4.17:1, and the rest are fairly close after 2nd. With decent power, the 3.73's and 4R run out of rpm in 3rd gear. The 6R will demand a big R&P change, 3.08 is my plan. The cost will be at least $4k by my guessing at costs, for many things required to do it.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
So I found out that the 96 limited I'm looking at is 2wd, but today I found a 98 Red Eddie bauer also 2wd with the 5.0. Guy is asking 700. The Trans is bad. Going tomorrow morning to see it and make an offer. Gonna offer 500, but the paint is really nice still. So maybe I'll go high as 700. Then I get to have a 5.0 Ex too after I'm done with this one.
- June 17, 2004
- Knoxville, TN
That's good. Plus if you really want the AWD, it's not complicated to hunt the several front drive parts, and swap it. Since the trans would be out, you can handle the two trans parts to swap out, and finding a solid AWD(BW 4404) or 4WD(BW 4406-big) TC might be fun for you.So I found out that the 96 limited I'm looking at is 2wd, but today I found a 98 Red Eddie bauer also 2wd with the 5.0. Guy is asking 700. The Trans is bad. Going tomorrow morning to see it and make an offer. Gonna offer 500, but the paint is really nice still. So maybe I'll go high as 700. Then I get to have a 5.0 Ex too after I'm done with this one.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
I ordered the heat socks. Those arrived today. After assessing all that has been done and what is left. I think I can button the engine work up and fire this thing back up on Sunday. Worked all day today. Working most of the day tomorrow.I remove the metal plug wire protectors and I run the fiberglass heat socks you can get at auto part stores
My trucks run Taylor wires and headers so I don’t have any good pics of routing them on a stockish truck but I will look through my pics and see
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
That makes sense. But the Awd isn't a deal breaker. Especially in Las Vegas. Just working on this 98 has renewed my love for the 2nd Gen EX. And I really like the 5.0/4r70w combo. So why not have one for myself while I can find one, or two....That's good. Plus if you really want the AWD, it's not complicated to hunt the several front drive parts, and swap it. Since the trans would be out, you can handle the two trans parts to swap out, and finding a solid AWD(BW 4404) or 4WD(BW 4406-big) TC might be fun for you.
- June 17, 2004
- Knoxville, TN
Ditto, they are fun to drive for an SUV, small enough to get around easily etc. I have the front drive shaft out of my black 98, after the AWD locked up that made it 2WD. It's harder to drive that given the mild tire spin. With AWD it cannot spin the tires ever except on snow or ice. In the rain you just hammer the gas whenever you like.
Find another one, good idea, it's nice to have identical vehicles from time to time.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
I had a 98 Navigator for many years that had selectable AWD. Was fantastic in the rain in Vegas. Very sure footed.Ditto, they are fun to drive for an SUV, small enough to get around easily etc. I have the front drive shaft out of my black 98, after the AWD locked up that made it 2WD. It's harder to drive that given the mild tire spin. With AWD it cannot spin the tires ever except on snow or ice. In the rain you just hammer the gas whenever you like.
- June 17, 2004
- Knoxville, TN
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
That's a beautiful Transfer case!Funny, that's the BW 4406 I got for my truck years ago. I also found the GEM from one of those, thinking to make the switch four position, which had a 2WD selection.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
Going to see a 98 Eddie Bauer 5.0 now. Wish me luck.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
Well the 98 Eddie Bauer is decent. Trans is bad, thats no problem. I would have bought it but the people bought it 6 months ago, signed the title and never had the title transferred. So they need to go to the dmv.
Kidd7
- January 13, 2014
- RTP, NC
- 2000 X AWD EB 5L
Once they get the title work done, are you getting it. Cuz you need a new project soon. LOL
I just picked up another project, has to go to another forum. 91 Jeep YJ.
SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
I wish, they sold it already. It was in pretty nice shape outside. Dirty inside, but not horrible.Once they get the title work done, are you getting it. Cuz you need a new project soon. LOL
Similar threads
- Replies
- 33
- Views
- 1,024
- Replies
- 10
- Views
- 7,954
- Replies
- 4
- Views
- 2,852
