ZWilson07
Elite Cowboy
- July 24, 2009
- Louisville, Kentucky
- 2000 Ford Explorer
Received a phone call today. The rest of the parts I've been waiting for have arrived at the part store, but looks like I will not be able to go pick them up till Friday. So here is a status update.
The engine is on the stand and I had removed all the old timing chains and cassettes except the chain for the balance shaft. I've been cleaning cavities and wire brushing some surface rust on the block. Today I replaced the balance shaft chain, tensioner and guide. I used 2000StreetRod's thread as a guide: Balance Shaft Timing Procedure. I would like to add a note that I found in my Hayne's manual. "DO NOT remove the balance shaft sprocket bolt."
And a quick hello to ZWilson07. Thank you for posting and good luck to you on your project.
Thank you.
Sounds like you're on your way
