killersdad
- September 15, 2023
- Granville NY
- 1998 Explorer XLT
Hello all here, I am new to this forum.
I installed new front brake pads last week and noticed a slight pull to the right when braking.
So I ordered and installed new front brake calipers as the old ones were crusty.
While changing the calipers out there was a noticeable grunt/burp like noise that occurred.
After changing the calipers the pedal was expectedly soft so I did a 4 wheel bleed with new synthetic fluid.
After the bleed the pedal now goes to the floor with no resistance and makes a wooshing sound.
Did a second bleed with no change.
System is tight with no leaks and it bled out fine with no air.
Help!, and thanks in advance., Killersdad
Called a mechanic friend and he thinks the ABS pump is air bound and it is hard to bleed.
Anyone have a hack for this? Thanks, Killersdad
