2.5L Ford what? Your profile shows a '98, 4L.
If you mean for your '98 4L, I'd think the easiest and most clean looking route would be pull the overhead console from a junkyard, wire it up using the connections shown on wiring diagrams (probably a relevant one is linked in my sig below), then you need to add the sensor itself and I forget where that is located (behind the grill?) but could also be pulled off a donor vehicle at a junkyard.
