BAPorterfield
- December 30, 2013
- Tallahassee, FL
- 1999 Mazda B2500
Truck sits and idles great, as soon as you try to drive it around the block it starts skipping on cylinder 4. Started with EGR valve, it was clogged all the way through to the intake, so I cleaned it out. No difference. Checked fuel pressure, 64 steady, checked compression, all fine. noid light flashes, and can hear fuel injector firing with stethoscope while skipping. So has fuel, and checked fire while skipping, it's fine as well. Mechanic talked me into a new head, made no difference. New coils, new plugs and wires, no difference. Am thinking maybe crank sensor or ECM. if it's firing and has fuel, maybe computer is glitching and doing right thing at wrong time? also replaced injector on cylinder 4, and still no difference, except about a grand chasing this issue from my wallet. I replaced timing belt, tensioner, water pump, thermostat and all that good stuff while I was in there doing the head. The skip is only on cylinder 4, which leads me to believe electrical. I plan on trying ECM next and Crank sensor. Also trying to find out if this model has a cam sensor as well. Thanks for any help anyone may offer.
