Mark Alexander
- August 26, 2019
- Douglasville, Georgia
- 1994 Ford Ranger
Was able to get fuel to rail by jumping relay, so wiring to pump from relay is good but still no sign of life from engine when spun over. Figured if we could get fuel up there it would run, but nothing. Spraying start fluid in the intake produces backfire, and plug wires are firing at coils, so there is fire, fuel, but no run. There’s no power from the ECM to the fuel pump relay. That wire (LB/O) comes from pin 22 of ECM, thru the relay coil to energize relay, then comes OUT of the relay as a RED wire which goes thru this spider looking connection, and to the injectors as a parallel circuit to power all 6 injectors.
At this point I have to decide whether this little truck which has new tires, lots of TLC and love applied to it (nothing junky about it) is worth the $600, having it towed 11 miles to my home, and a new ECM which is very suspect. ECM ranges in prices of $99, to $225.....not sure why....Opinions needed please. I’m thinking the ECM is bad and not powering the injectors and fuel pump circuit. Would y’all buy it?
