Year | Engine | Trans Options | Notes |
91-94 | 4.0 OHV | A4LD, M5OD | OBD1, |
95 | 4.0 OHV | 4R55E (95 only), M5OD | OBD1.5 (Pre-PATS), Speed sensor in trans |
96 | 4.0 OHV | 4R55E (96 only), M5OD | OBD2 (Pre-PATS), Speed sensor in trans |
| 5.0 OHV | 4R70W (96-97 only) | OBD2 (Pre-PATS), Speed sensor in trans, GT40 heads, internal EGR |
97 | 4.0 OHV | 5R55E (97 only), M5OD | OBD2 (Pre-PATS), Speed sensor in trans |
| 5.0 OHV | 4R70W (96-97 only) | OBD2 (Pre-PATS), Speed sensor in trans, Early models GT40 heads (internal EGR)/later GT40P (external EGR) |
| 4.0 SOHC | 5R55E (97 only, OHV or SOHC) | OBD2 (Pre-PATS), Speed sensor in trans, variable length intake |
98 | 4.0 OHV | 5R55E (98 only, OHV or SOHC), M5OD | PATS, ABS speed sensor |
| 5.0 OHV | 4R70W (98-01 only) | PATS, ABS speed sensor, Updated DTRS, Updated internals, GT40P heads, external EGR |
| 4.0 SOHC | 5R55E (98 only, OHV or SOHC) | PATS, ABS speed sensor, variable length intake |
99-00 | 4.0 OHV | 5R55E (99-01 only, OHV or SOHC), M5OD | PATS, Return-less fuel system, ABS speed sensor |
| 5.0 OHV | 4R70W (98-01 only) | PATS, Return-less fuel system, ABS speed sensor, Updated DTRS, Updated internals, GT40P heads, external EGR |
| 4.0 SOHC | 5R55E (99-01 only, OHV or SOHC) | PATS, Return-less fuel system, ABS speed sensor |
01 | 5.0 OHV | 4R70W (98-01 only) | PATS, Return-less fuel system, ABS speed sensor, Updated DTRS, Updated internals, external EGR |
| | M5ODHD (Sport only) | |
