2 1/2 inch suspension | Ford Explorer Forums
Fastwboy
Ok I have a 94 X sport. It already has a 3 inch body lift on it and I was thinking about a 2 1/2 suspension lift. Now I read something about if you already have a body lift you need something else to install the suspension What is it? And Which one should I get and Which is the easiest to do?
2 1/2 duff kit www.jamesduff.com u don't need anything special to install it with a combo of body suspension.....it's an easy install there is a write up about it
I don't think that it is that you "need" something.. it is just that some people don't like mixing body and Suspension lifts. I see many people with them and don't know what the problem is.. unless they just don't like the idea of a body lift.
Here's the writeup I did (I know 2 pic links are bad.. they weren't mine)..
http://mark.legendz.com/install/duff-install.html
If you can afford it, I would replace the rear springs with a set of OME-36 springs (2"ish lift) instead of using the add-a-leaves that come with the Duff lift. They ride much better and flex tons better than stock springs with an add-a-leaf
~Mark
