2.3 ecoboost intake valve carbon
toad350
San Angelo Tx
16 Explorer XLT ecoboost
Does anyone have any info/experience with carbon build up? Anyone know what if anything ford has changed in the new gen engines to elimate the problem?
I have seen threads on this but not since the 2.0 went away, just curious 40000 miles on my 16,no problems so far!
B normal to have water/oil in air intake duct/3.5 ecoboost? Stock 2011 - 2019 Ford Explorer Discussion 8
2 Cold Air Intake for '12 Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 1
K Ecoboost Turbos on Ebay? Stock 2011 - 2019 Ford Explorer Discussion 2
W 3.5l Ecoboost Misfire/Catalytic Converter Stock 2011 - 2019 Ford Explorer Discussion 7
B P0455 Code-Purge Control Valve Location 3.5 Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 4
F 13 explorer 2.0 Ecoboost rattle Stock 2011 - 2019 Ford Explorer Discussion 3
J 2016 Explorer 2.3 Ecoboost Idle Issue Stock 2011 - 2019 Ford Explorer Discussion 11
1 Ecoboost Blown Turbo Stock 2011 - 2019 Ford Explorer Discussion 3
D Seafoam in an Ecoboost? Stock 2011 - 2019 Ford Explorer Discussion 2
B 2016 XLT ecoboost (non sport) Shuts off while driving Stock 2011 - 2019 Ford Explorer Discussion 4
P 2.0 Ecoboost Alternator Replacement Stock 2011 - 2019 Ford Explorer Discussion 0
K Ecoboost Carbon Buildup... Stock 2011 - 2019 Ford Explorer Discussion 11
T 2016 Explorer 4 Cyl Ecoboost Rough Idling Stock 2011 - 2019 Ford Explorer Discussion 24
K 2.3 EcoBoost PTU fluid change result. Stock 2011 - 2019 Ford Explorer Discussion 7
S Spark Plug job on Explorer Sport 3.5L Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 26
T 2.3 Ecoboost carbon build up Stock 2011 - 2019 Ford Explorer Discussion 8
B Ecoboost timing chain replacement Stock 2011 - 2019 Ford Explorer Discussion 10
R "2.3 Ecoboost 4x2 Reliability? Stock 2011 - 2019 Ford Explorer Discussion 10
W 2.3 EcoBoost Waterpump Replaced at 26,000 miles Stock 2011 - 2019 Ford Explorer Discussion 2
E 3.5l Ecoboost vs Raptor 3.5l Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 8
R 3.5 Ecoboost Limited Stock 2011 - 2019 Ford Explorer Discussion 9
D 2.0 Ecoboost wastegate death rattle Stock 2011 - 2019 Ford Explorer Discussion 1
G 2016 ecoboost sport is a turd Stock 2011 - 2019 Ford Explorer Discussion 4
M F150 Ecoboost Vs Explorer Stock 2011 - 2019 Ford Explorer Discussion 0
S Can I put an EcoBoost in my 2011 Stock 2011 - 2019 Ford Explorer Discussion 35
L 3.5L EcoBoost Turbo Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 13
J Explorer vs Nav/ ecoboost 3.5v6 differences Stock 2011 - 2019 Ford Explorer Discussion 14
M 2013 Ecoboost 2.0 crank wheel alignment Stock 2011 - 2019 Ford Explorer Discussion 3
V The 2.3l Ecoboost XLT is fast... Stock 2011 - 2019 Ford Explorer Discussion 8
D 3.5L Ecoboost Owners - What MPG are you getting? Stock 2011 - 2019 Ford Explorer Discussion 97
J 2017 XLT, 2.3L ecoboost AWD tranny concerns Stock 2011 - 2019 Ford Explorer Discussion 3
O 2.0l Ecoboost upgrade to 3.5l V6 Engine Stock 2011 - 2019 Ford Explorer Discussion 0
R 2016 ecoboost explorer overheating Stock 2011 - 2019 Ford Explorer Discussion 5
Daheim111 Ecoboost 3.5 / max continuous RPM known ? Stock 2011 - 2019 Ford Explorer Discussion 6
S Does F-150 use same ecoboost as Explorer Sport and Platinum? Stock 2011 - 2019 Ford Explorer Discussion 13
H Your Best Mileage from a 2.3L Ecoboost? Stock 2011 - 2019 Ford Explorer Discussion 24
B 3.5L EcoBoost: 2017 Platinum Engine Stock 2011 - 2019 Ford Explorer Discussion 2
mgmgmg Twin Turbo V6 3.5L Ecoboost vs N.A. 3.5L V6 Stock 2011 - 2019 Ford Explorer Discussion 14
B Need opinions, looking at buying an Ecoboost Explorer! Stock 2011 - 2019 Ford Explorer Discussion 22
P Oil catch can 2.3l ecoboost Stock 2011 - 2019 Ford Explorer Discussion 0
E EcoBoost Fuel Injector Issue Stock 2011 - 2019 Ford Explorer Discussion 14
P 2.3 ecoboost Stock 2011 - 2019 Ford Explorer Discussion 12
S Fuel Injector Cleaner for Ecoboost Engines Stock 2011 - 2019 Ford Explorer Discussion 4
T EcoBoost 2.3L noise around 30 MPH when accel Stock 2011 - 2019 Ford Explorer Discussion 43
M EcoBoost? Stock 2011 - 2019 Ford Explorer Discussion 30
C 2016 Sport - 3.5L EcoBoost "Chugging" on cold starts Stock 2011 - 2019 Ford Explorer Discussion 25
R SHO ecoboost engine cover fit? Stock 2011 - 2019 Ford Explorer Discussion 0
G 2.3L Ecoboost Question Stock 2011 - 2019 Ford Explorer Discussion 8
H Ecoboost differences Stock 2011 - 2019 Ford Explorer Discussion 2
P 2012 Explorer 4.0cyl Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 1
Similar threads
