RPM289
- March 31, 2017
- Mount Olive, NC
- 2000 4wd Explorer 4.0
I pulled the 4.0 out of my new explorer for rod bearing knocking and when i went to unplug the big plug behind the engine going to tranny all the wires pulled out of the plug on the engine side. Does any one have a pin to wire color chart to put these back where they go?
Second Q i went and bought a 4.0 SOHC out of a 2000 exp sport 4wd auto but harness is different than mine it does not have plugs at back of block had to pull harness off trans to get engine harness. Upper intakes were different also. So if i can't fix my old harness with the second one work?
Thanks!
Mike
Thanks!
Mike
