budwich
- May 4, 2005
- Ottawa, Ont
- 96 XL
GEM swap was after melted wires were repaired I believe. I still have the GEM and will hang onto it untill done then EBAY. If I remember correct the pins that were burnt on the shift module were 6 and 10. They were burnt off between the board and the pin connector where the plug in goes. I owe you guys all steak dinner and a beverage if you are ever my way![]()
OK.... it does make some "sense" but ultimately the question is that outside of "fixing" those connections (resolder????), did you actually test the rest of the board after the "repair". I am not sure which "chicken or egg" happened first but I suspect you have a ignition issue that might have took out your shift module.... having said that ... do you / did you run your vehicle in "auto 4w" all the time / most of the time????
further... burns is never good... especially when there is a solid state device involved ... in this case the circuit has a diode in it... you probably need to "buzz" the board with some basic checks to resolve the blowing fuse issue.
