y2kxploder
- December 9, 2011
- Toronto
- 2000 Exploder
Hi all,
I'm new to these forums, hoping someone can lend some advice. I apologize in advance for the long winded story.
I just recently bought a 2000 Explorer, 4.0 OHV, 4x4 with about 150,000 miles.
I've had the vehicle for about a month, and ever since I bought it, it's had a grinding sound (sounded like wheel bearing) coming from the front right side. I replaced both right and left bearing/hub assemblies, and took it out for a drive. The initial sound the I thought was bearing noise is still there, and at about 65mph I started to get a little bit of steering wheel shake. I took my foot off the gas and it stopped. I accelerated up to about 70mph and it seemed ok. I hit a VERY small bump in the road and the steering wheel started shaking like hell. So bad that I almost lost control. I slammed the brakes and the shake stopped instantly. I took it home and put it up in the air, half expecting to see something loose or broken, and everything looks perfect. I re-torqued everything that I had taken apart for the initial hub/bearing replacement, and took it out again. Same issues.
I never had ANY of these problems before I replaced the hub/bearing assemblies, so I'm completely confused.
I was thinking CV joints, but I have no clicking at all when turning, in forward or reverse, everything is smooth.
Outer tie rods were done about 6 weeks ago.
Any ideas?
Thanks.
Any ideas?
Thanks.
