masospaghetti
- October 22, 2006
- Huntington Beach, CA
- 98 XLT, OHV, 4D, 4x4, 5M
I saw in my owner's manual that the towing capacity for my Explorer is 2,200 lbs, assuming the cabin is empty except for the driver.
Do you think it would be safe to tow a car dolly with a relatively small car on it, total weight approx. 3,000 lbs?
I only ask because 2,200 lbs seems ridiculously low to me, for a vehicle with a full body-on-frame and a 4.0 liter engine. It's the OHV motor with a 5-speed manual transmission, 3.23 gears, 2WD, 2-door. Also, where is the limitation coming from? Is it the motor, the cooling system, the clutch, gears, etc? Obviously, the heavier 5.0 Explorers could tow upwards of 5,000 lbs, so the frames, driveshafts, and rear ends shouldn't be the limitation.
Thanks all.
Thanks all.
