Billbent33
- March 10, 2006
- Florida
- 2000 xlt
2000 xlt idle is high - V8 engine- 5.0 Liter-
Hi all
Trying not to beat a horse that is obviously dead.......nonetheless...
2000 XLT with V8 5.0 L engine and 2 wheel drive.
My 5.0 engine has consistently idled high ( 1200 to 1500 Revs) since replacing stock air filter with K& N. Having read previous suggestions I:
1. cleaned the throttle body with TB cleaner to reduce sticking
2. replaced IAC valve
3. Checked for vacuum leaks
4. disconnected battery for about an hour.
5. went to autozone and checked codes..( throws a P-1506 which shows up as Idle speed control). Was advised that 2000 explorers and some earlier years do not have ISC and correcting problem was done by replacing IAC instead.
6. Engine temp is within normal limits
7. Throttle adjusting screw is backed down enough so it does not even touch the spring loaded plate on the Throttle connection
Now....I'm stuck like a carboned up TB but TB cleaner wont unstick me..
Unplugging the 2 wire lead to new IAC valve does not change rpms ( should it? is new one bad?)
Should I take off IAC and tape over the holes to prevent any air flow into TB and see if that makes a difference?
Have not cleaned MAF but will do it today
Is there an ISC module on the 2000 xlt or only the TPS?
Any other suggestions?
Thanks for your help
Bill ( Red Eye)
PS Since initial post I have cleaned MAF, double checked for vacuum leaks and recleaned the IAC module...
Tapping the throttle stop tab and forcing it down to contact the idle adjustment screw reduces idle to tolerable limits ( about 800 revs) but causes accelerator to stick. Tapping the accelerator to unstick it frees up the Throttle Body sticking problem but won't let the idle return to the 800 RPM range....? Time for a new TB ???or can I take the old one apart and clean up the butterfly valve shaft and bushings if there are any??? Or can I replace the throttle shaft or butterfly valve or external return spring or???
I'm stumped.
Thanks again,
Bill
Hi all
Bill ( Red Eye)
I'm stumped.
Thanks again,
Bill
