mturner2003
- June 12, 2020
- Zanesfield
- 2001, XLT, 5.0 AWD
Hello everyone!
I was blessed to receive a 2001 XLT, 5.0L, AWD with 147k miles for FREE from my neighbor.
Long story short, had a misfire code, guy tried to change the spark plugs himself and wound up breaking 4 off in the block. It sat for ~ 2 years until he came over and asked if I wanted it, knowing I'm a 4x4/off-road guy. When I saw the 5.0L, I said... sure, I'll take it, lol.
As of today, was able to extract all the spark plugs and it runs just fine. I'd like to build a Mega out of it. Kind of my specialty, as I've built several in the past. Been a few years and I'm itching to build another. I've had an extra set of 5 tons laying in the back of the shop for almost 6 years now.
So, with all of that said... I want to remove the AWD t-case. Thinking through it, I think I have several options but I wanted to check with some folks that know these transmissions and t-case pairings. I don't know anything about Explorer drivetrains. Feel free to copy my questions below and answer below when replying.
1. Remove the AWD case and install a 4x4 case. I would like to have the extra low range. I will be mating it to a drop box (SCS, chain case, etc) as well. So, the question is will an OEM 4x4 case mate to the adapter on my transmission now? What is the model of case I need? Or, does the adapter have to be changed as well to make the 4x4 case?
2. Convert transmission to 2wd. Then mate to my drop box. Even though I'd like the extra low range with a 4x4 case inline, this option is ultimately more suitable. My assumption is that the output shaft on a 2wd will not be as far back from the engine as a 4x4 output shaft. This is ideal because it allows me to center my drop box so that my driveshafts are roughly the same length. In most cases a 4x4 case output shaft is much further back than a 2wd, which makes me have to put my drop box further back causing a super short rear drive shaft and super long front driveshaft. Make sense, haha? Am I able to convert my current transmission to 2wd?
3. Or, am I better off just purchasing a 2wd transmission? Which model would I need?
I'm asking these questions because I've tried doing some research and some folks were saying that a 2wd transmission was longer than a 4x4. But, they were not thinking about my specific case. Yes, the tailshaft is longer on a 2wd. But, after adding a t-case to a 4x4 transmission, which output shift has a longer distance from the engine block? I want the shortest possible.
Sorry for such a long post. Any support is greatly appreciated!
