Scout3
- August 19, 2010
- Orange Park. Fl
Hi All,
Hope you can help me. I am trying to help a friend long distance. He has a 2001 Ford Ranger and at this point it is about all I know. The truck has had the check engine light on since he bought it but it runs pretty good. It recently started flashing the airbag light with a code 46. I read that that is showing a failure in the driver's seat belt and he is going to check the connector under the seat for that. He has had different scanners hooked up and they will not communicate with the PCM. I told him to check the #17 fuse first. He has very little money so any help will be appreciated. I thought I might look around the u pull its around here for a PCM to send to him. What would I have to know to get a PCM that would be plug and play. Any hints to what pins on the PCM to check for power. I have a pretty good background and wish I was there to help troubleshoot these problems. He needs the truck but it will not pass the safety inspection with the flashing airbag light. The computer can wait if necessary. Thanks for any help.
Ed
Ed
