solson
- November 2, 2010
- Barstow, CA
- '01 Sport Trac
Hey everyone, I'm Steve...I'll make my intro a bit later in the right spot.
I've been having a problem with my Sport Trac for quite some time now and didn't know exactly how to approach it. I'm hoping to lean on your expertise here in the forums to give me a little insight before I either try and fix it myself or take it in to have it repaired.
Periodically I've been having an intermittent problem starting the truck; it turns over just fine but won't start. If I keep at it long enough, it will finally start and runs just fine. Through my non-professional troubleshooting, I firmly believe it's a problem with the fuel system. I've been Googling the heck out of this problem but not sure where to begin on fixing it.
When the truck does start, I can hear the fuel pump kick on and it starts up instantly. When it doesn't start, I cannot hear the pump kick on at all and I'm left there for long periods of time with it turning over, but not starting.
I thought right away it must be the fuel pump, but when the truck is running, it has never once sputtered or cut off. This problem only occurs during ignition, and intermittently. I also thought maybe it's the inertia switch, fuel filter, pump relay, or fuel injection, but I'm not sure how to troubleshoot each one without just replacing them.
If this comes down to a fuel pump problem, I will most likely just take it in for service because that's a bigger job than I want to take on.
So, the truck always turns over, but sometimes doesn't start for minutes or up to 10+ minutes. Right now it's not starting at all (whatever the intermittent problem is may have completely failed at this point). When it does start, it never cuts out. So does that rule out the fuel pump and narrow it down to what turns the fuel pump on?
I would very much like to fix this problem myself and not pay excess money to a shop to if I don't have to. I appreciate any and all advice as to how I can troubleshoot and fix this problem. Has anything I said lead you to believe I should start somewhere first?
Thanks a million!
Thanks a million!
