magnum01
- November 8, 2003
- arnold missouri
- 2001 Sport 4x4
How do you drain all the fluid for the 30k service? dropping the tansmission pan and changing the filter only drains about 35% of the fluid. How do you get the rest out? There is no access to the torque converter without removing the transmission. The converter holds a lot of fluid. Do you open the tranny cooler lines to drain the cooler and torque converter or do you drain/ flush the system by draining and filling through the cooler lines at the same time which can waste a lot of good fluid
