cdsl227
- June 25, 2001
- Brooklyn, NY
- 2001 Explorer XLT
Actually on the gears I've been checking and it's called "runout" it's the amount of inconsistency in the thickness of the ring and/or the carrier. The only way to "fix" it is to run them on a big lathe...and that's not happening.
I pulled the ring off and hit it with a Scotchbrite pad then did the carrier...it seemed to bring it down to a workable number about 0.002 which can be made up for in the backlash. They should break in to a consistent wear bringing the entire carrier and ring into spec...if I take the middle ground on the backlash.
Randys' sent me the wrong axle seals or I'd have been done with the pumpkin today. It seems nobody has the 2.625" seals, everybody has the smaller seals. I'll have to try and hunt them down tomorrow.
For the T-Case I'm going to be getting an Atlas II from Cory...I just want to be sure I've got the axle completed and then grab some tires and rims, I'm starting to think 37x12.50 instead of 35s. I just wonder if the stock axles will hold up or if I need to get something a little beefier. Then again I went with 4.56 for the front the rear has yet to be ordered...so I might settle on 36x12.50.
I'm thinking I'm about a month off from ordering the T-Case.
Damn, I was hoping to get this done by September 03' and it's starting to look like February 04'.
