STLMach1
- October 18, 2011
- Missouri
- 2002 Ford Explorer
2002 Explorer - FIXED - Heat is now working!
Greetings folks,
I bought a 2002 Ford Explorer Limited back in February of this year. The heat worked well during late winter/early spring but now that it's cooling off again and I'm turning it back on for the first time in a while to find that it's blowing cold air rather than warm.
It has the climate control feature that allows you to set a desired temperature rather than manually turning a temp control dial. I believe that the controlling unit knows what it is trying to do (meaning it's trying to heat) as when I run the temp down to its lowest setting (60 degrees), the blower fan will virtually shuts off. With the cab temperature being cooler it knows that it doesn't need to add any air. When I run it up to its max temperature (90 degrees), the blower progressively increases in speed attempting to warm the interior. The problem seems to be that the engine coolant may not be making it into the heater core to provide a heat source.
Even when I try manipulating the temperature through manual controls rather than running it in Auto mode I essentially get the same results. When transitioning settings, every now and then I'll feel some heat but it quickly fades back to cold air.
Oddly, when I've got it set to 90 degrees in Auto mode and switch to manual (say the vents), the A/C light comes on giving me them impression that despite being set at 90 degrees when in Auto, that mode was in fact running the A/C. Is this a possibility? How can you truly tell when the compressor is engaged (i.e. cooling) and not just free spinning (i.e. not cooling)?
I recall there being a valve in the coolant lines somewhere between the radiator and the heater core that would stop the flow of hot water when you weren't adding heat to the incoming air. Is this still present on the 2002 Explorer and could this be the issue? I seem to recall this having been a problem on a 1986 Bronco II that I owned years ago.
I also recall there being a door in the heating/cooling duct work that might play a part in the air source (hot or cold) coming into the cab. Might this be somehow inoperable (vacuum driven?) or possibly stuck?
Could there be relays involved in all of this that aren't working or worse, something wrong with the temperature controlling unit essentially issuing incorrect directions to the devices it manipulates when regulating temperatures?
This is a little out of my element so any direction that you can provide would be MOST appreciated.
Thanks,
Michael
Greetings folks,
Thanks,
Michael
