Socc91
- January 29, 2016
- 2002 ford explorer
I have a 2002 Ford explorer and am having an overhesting issue. First i had a hose that cracked and started leaking so i replaced it (first sign of something wrong to come). I noticed sfter that the car would hear up to normal temperature in normal amount of time but i would still have no heat. After about 20min of driving i would have hot heat. After 30-40 min of driving my idle rpms would start to increase to about 1700. Around 40+ min is when the car begins to overheat and i need to blast the heat to prevent temp from going too high. I have since replaced the thermostat and flushed the system, still having same issues. I dont want to start guessing on parts to find this problem. I assume it culd be anywhere from radiator, heater core, water pump, clutchfan or even a crack in the i take manifold (although i see no leaks anywhere). Anyone have any suggestions?
