Jackie wilhite
- January 28, 2020
- Cullman, Al
- 2002 explorer xlt
I have an 02 explorer 4.0. It has a miss at idle, it smooths up above 2000 rpm but it has a lack of power. I don’t have fancy machines so I did some shadtree checking. Cylinder 1 has fire to the cylinder, I checked at the coil, removed the plug, plug is firing. I disconnected the fuel injector and there was zero change in the engine. I replaced the injector and it did not fix it. Is there something I am missing. Should I get a noid light and see if it is powered. I have 5 other injectors to check just in case, but I’m doubting the new one is bad. Is there a common problem/eco etc I am missing?
