EyeintheSky57
- April 25, 2010
- Tampa, FL
- 2002 Mountaineer
From what I can see, the passenerger side or upper right corner of my air recirculation door appears to be leaning or hanging downward, making me think it's come out of it's attachment point. The left side or drivers side, appears to be still level and attached. It hasn't fallen to the bottom of the box yet like in those pictures at the web link.
That is definitely possible. Nothing holds the door snug in place. It is kind of a free-floating hinge so if that hinge vibrates left or right, it will fall. And, if one side fails, it prevents proper operation AND, eventually, the other side will fall too blocking the suction of the blower.
That is the point where I noticed it. All of a sudden, I was barely getting any air flow but the blower still sounded full blast.
As a (hopefully) permanent fix, I drilled a pinhole in the right side nub and threaded a regular ole paper clip through to prevent the right side from ever falling in again. Easy fix that FORD should have engineered into the door.
