2002 power steering trouble | Ford Explorer Forums
gwilkrrs
2002 explorer
2002 v8 explorer with 125k. out of nowhere the truck starts being hard to steer then "releases" and turns free. I checked fluid and was full. looked under and rack was damp to slightly showing wet.... fluid (likely original) smelled a bit burnt. I pulled the line off going to the cooler and drained the cooler and the resovior and added new fluid........ now I am trying to determine what is getting ready to fail.....
thoughts to try or look for? thanks.
Air in system? Could also be bad ball joints? If u disconnect tie rods, see if wheels turn easy. Have had bad ball joint make it so steering wheel wouldn't return to center after making a turn. Would have to manually straighten wheel out.
I will check those as well thanks!
Sounds like the rack is failing. If it was the pump it would be a consistent drag.
My ranger did the same thing back in the day, we flushed it and it worked for a while. Might try draining again, filling, work wheels a few turns and repeat until fluid stays red.
If that doesn't do it then I'd be looking for a new steering rack.
Is your belt squealing?
Also, the belt can slip after going through a puddle.
no squeeling I don't think the belt is slipping
pretty sure bad-old fluid and a weak rack
