2002 - stuck in 4L | Ford Explorer Forums
2002 - stuck in 4L
kjbach1
PA
2002 ford explorer sportr
This site sucks! All I wanted to do is find out how to get the transfer case out of 4L and I keep getting adds for a download for videos. What gives? Impossible to navigate this site.
Did you try putting it in neutral before shifting out of 4 low?
If that doesn't work you may have a transfercase with a shift motor on the back. If that's the case as a temporary fix you can remove the shift motor and move the shaft manually with Visegrips.
You must understand that not everyone checks in here everyday, it might take several days till someone looks that has and answer for your problem. In my opinion Ricks advice is very good.
