NewGreenie
- September 18, 2008
- 2002 V6 XLT
My 2002 XLT v6 explorer with 130,000 is slipping when trying to go from 2nd to 3rd gear(at 20 mph). The revs spike up without shfting. I can back off the gas and tap it or going down hill it will catch and I can use the upper gears fine. It has 5R55? not sure if it is E, S, or W.
From scanning the forums I was hoping I coud replace the selonoid to fix it. When I took off the trans pan I fould a 1 inch metal wedge. I believe its an anchor that attaches to the intermitiade band. There was no other metal in the pan. Im thinking of pulling the trans but the biggest problems is I would have to do the work in my driveway. Hopefully someone could help me with the following questions.
1. How high would I have to get it up to pull the trans from underneath? Have 17 inch jack stands that I was thinking of building up using 1 foot pieces of 2 by 12. Might be able to get hold of 24 inch jack stands.
2. How do the anchors attach to the bands? Is it likely the band broke or could the wedge just slipout? Im guess that whatever the wedge anchers to broke.
3.What is the procedure and tools need to get at the bands? Any pictures or links would be helpful. Also anywhere to buy bands or parts? Thanks, Gary
