2003 ABS Issue | Ford Explorer Forums
2003 ABS Issue
03Explo20
Jonestown, Pa.
2003 Explorer XLT
So, bought a new set of tires for the Exploder and also did some spray on rust proofing and have noticed some ABS issues that came up. Dash light comes on every once in a while then goes back out. I've noticed the pulsating in the pedal when braking on bumpy roads. It does that a few times then goes away. I'm leaning towards the new tires but am also wondering if I may have sprayed some rustproofing **** that may have gotten someplace it shouldn't have. I ordered some new front ABS sensor cables as mine are looking a bit ****ty. If not the new tires then maybe one of the cables is bad?
Anything else I could check out to be totally sure? No codes in the ECU and like I said it is sporadic but causes the heart to start pounding a bit harder when it happens.
