spoulson
- December 18, 2006
- Middletown, DE
- '03 XLT
Hello,
I've had this ABS warning light come on intermittently while driving for several months now. The truck drives fine, but the ABS has falsely kicked on briefly during braking only once in a while when not on a slippery surface. I need this fixed soon because it's due for inspection in November.
I do all my own maintenance, but since I don't have a Ford scan tool that can diagnose the ABS light, I'm either at the mercy of the dealer service, have to invest in the scan tool, or solve the issue manually.
After some searching around, I haven't found a solution that applies to the 03's. From what I have found, most say it's a fault in the rear with either the speed sensor on the diff or one of the pickup wheels.
I took a look in the rear and found the sensor. It's a little tight in there, but not sure if I have to drop the diff to get at it. I imagine there is a pickup wheel in there, too. I haven't looked closely at the front yet. I priced out a new sensor at Fast Parts Network, but it's ~$60 so I didn't want to dig into it if I didn't have to.
How should I troubleshoot this? Thanks.
