2003 EXPLORER HEATING ISSUE | Ford Explorer Forums - Serious Explorations
EASIMOS
PHILA
2003 FORD EXPLORER XLT
HELLO, I HAVE AN 03 XLT 4.0 WITH MANUAL HEATING CONTROLS. THIS IS THE SECOND TIME I REPLACED THE ACTUATOR SO I'VE BEEN THROUGH THAT. I JUST REPLACED IT AGAIN. SO HERE'S THE ISSUE. WHEN I START THE TRUCK AND GO ANYWHERE, AFTER IT WARMS UP I PUT THE HEAT ON. NO HEAT VENT BLOWS, BUT JUST ROOM TEMP, HOWEVER IF I SHUT IT OFF AND TURN IT ON OR SWITCH FROM HOT TO COLD OR SOMETIMES EVEN SP-ERRATICALLY I WILL HEAR A DOOR CLOSEON PASS SIDE AND IT STARTS BLOWING HOT AIR. (ACTUATOR IS NOT CLICKING AND IS NEW). COULD IT BE BAD OR IS IT A DIFFERENT PROBLEM? OH AND AFTER I SHUT MY TRUCK OFF SAME PROBLEM ALL OVER AGAIN. STARTING TO GET COLD...
ANY HELP WOULD BE APPRECIATED.
Here is the search link for "2003 blend door" there are several different threads which may point you in the right direction:
Google Custom Search
