Hi All, My 2003 Explorer XLT 4x4, 4.0 77K miles driven lightly and never towed..Had a problem with the transmission not coming out of 1st gear unless I let off the gas pedal and kind of manually shifted it with the gas pedal and it would not go in to overdrive(5th). Then the overdrive light started to flash and it threw a service engine light. I went to auto zone to get the code read and it said P0775 and another code that said 5th gear ratio wrong. After reading these threads I replaced the solenoid in the trans and it did the same with no repair. I talked to a Ford tech at the local dealer and he said to replace the overdrive servo and adjust the band. I got him to do it and he update the trans programming and now it is back to new. I wish I knew if it was fixed before the reprogrammed was done but he did it all at one time. I wrote this thread because I was told by the dealer earlier and a trans shop that they would have to pull the trans for more testing or a rebuild which was expensive. The overdrive servo was done in 2 hours or less and only cost $30.00 for the parts and I gave the tech 200.00 for labor and the reprogram. I was going to do the servo myself but thought for 150.00 labor he new what to do if something went wrong(which I don't with transmissions).
I hope this may help others with these symptoms like mine, he said this is now common.
