Robert Whiteman
- May 14, 2018
- Shermans Dale, PA
- 2003 Explorer XLT
Hello, a fairly new member after purchasing a 2003 XLT 4wd 4.6L this past spring. 129,000 miles, slow leak in radiator and later found coolant leak from intake manifold. I just finished installing a new radiator and Dorman intake manifold. Reconnected battery, started right up, idling well, no visible leaks. Great.
Decided to move the car out of the garage to move drain pan and a few rags still under the car, but the car will not move, in reverse or forward. It tried, but wheels will not turn. It feels as if I'm trying to jump a curb. I did not try too hard since I have no clue what this could be. It drove fine since buying in in May of this year(2018), up until I parked it to do the work. I only worked on the radiator and intake. Nothing else(that I know of) was touched. Could it be from disconnecting the battery?
Again, it's trying to move, both forward and backward, but acts like the wheels are blocked. Yes, e-brake was off, but needs adjustment anyway, so wouldn't matter even if it was on. I've left it on a couple times when starting out until I realized the brake light was on.
I also noticed that the brake pedal seems soft, and almost feels as if there is little or no pressure in the lines. It is late, so I have not looked for any brake fluid leaking.
Thanks in advance for any ideas you might have.
Bob
Bob
