03Explo20
- January 4, 2013
- Jonestown, Pa.
- 2003 Explorer XLT
Noticed a metallic popping noise coming from the front suspension area. I believe it might be a exhaust heat shield but found nothing loose or even close to anything to make the heard noise. The shields around the cats are both tight and the shields behind the pipes are movable but not hitting anything.
It almost sounds like it did when the front ball joints needed replaced and I got that loud pop. Both are brand new and when stepping on the truck and flexing the suspension, I can't get the pop.
Anyone have any suggestions of what else to check? Can the heat shields be cutoff without much trouble? Could this even be tranny related or maybe the tranny support bar stretching??
I'm wide open for things to check!
Thanks, fellas!
*** forgot to mention that the popping noise is not a "heavy" metal type sound but sounds more like tin or aluminum. This is why I'm thinking heat shields but cannot find one that is moving or hitting anything.
Thanks, fellas!
