Well, the rear brake was 100% locked up. I only drove it home about 1 mile, but like I said, it was 100% locked up. I had to get the RPMs up pretty high and slip the clutch like crazy to avoid it from stalling. My dad was behind me when I was getting it back home and he said the smoke was so bad that he couldn't see the back of my truck. You could smell clutch inside/under/around my truck for atleast 2 days. It drove fine other than the obvious hot spots, so I figured the clutch was alright still. While it's out though, I might as well put in all new so I don't end up with a fawked clutch by having to slip it a lot offroad, etc.
EDIT: I used some Duplicolor 1200* heat paint on the y-pipe and cats. I had my neighbor reweld the heat sheild on the y-pipe, since it's right under the trans, and pulled the rest of them off. My friend took his show truck (Avalance on Lexani 20s w/ 37s, carputer, etc.) up to a small exhaust shop that does work on lots of show vehicles, and he said most of the time, he paints the entire exhaust system with this to keep them looking pretty good even when the trucks get driven to the shows, etc. Figured I'd do the same while it's all out.
