f4i954
- March 7, 2016
- 2004 sport trac
first post on here, looking for help for a friend, thanks in advance.
i searched the forum but found nothing.
i found lots of charging problems but no info on the batt light.
one year ago, bat was replaced, batt was dead and original, so i just decided to replace it, 6 mounts after dead again, i tested voltage at the alternator (10 volts), removed it, took it to a local shop, bench test it, and was good (14 volts), charged the battery installed the alternator back and was good for another 6 mounts.
no voltage at the alternator, replaced it with a reman and its charging now, i did notice the battery light on the instrument cluster is very dim with key on, goes out when engine running witch is normal.
the question is what can cause it to be dim?? i did replace the cluster 4 years ago with a used one, don't recall if it was dim back then.
i tried finding a diagram with no luck, does this have a basic system or is it controlled by the engine module?
