camoxjeep
- November 23, 2008
- 2004 Exp
Friends Exp wont start. The other day drove home from work to get something, went inside and came back out and tried to start and it wouldnt do anything. Turn the key and nothing. When you turn the key to crank position only sound you here is relay under dash clicking (just twice for each key postition-not continuous). Checked the battery-fine. Tried to jump start it-nothing. I have all power inside-lights windows all gauges work. Took the starter out and had advance auto check it and they said it was fine. I tried the screwdriver across the two big terminals on solinoid and the starter turns but doesnt engage with the motor (not sure if its supposed too without the small terminal involved). Checked for power between small terminal and larger negative terminal on solinoid with key turned to crank position and no voltage at all. Could this be the ignition switch or PATS system? How can you check the ignition switch? thanks
Also this has the factory security system. when you dont have key installed it blinks as normal. (led is on top of dash in middle by windsheild-no other security lights). when you turn the key to crank the led stays on continuously (no blinking).
