2004 Explorer A/C & air only runs through defrost. | Ford Explorer Forums
Explorer363
Los Angeles, CA
04 XLT
This just started happening. The air and the a/c will only come out the defrost exits and the back seat. Any help would be appreciated. Thanks.
your going to have to check for vacuum leaks, or small loose hoses back in there. Also there are several electrical actuators also which can fail. try searching on Blend Door it shows you more of what goes on in there but blend door controls the temp not which vents. . .
It's not a blend door problem, it's a vacuum leak.
Do a search on this, some people have had problems with the vacuum reservoir
