PapaMelch
- December 1, 2015
- 2004 Ford Explorer
Hello everyone. I've been learning and following all the posts to repair the exploded timing cassettes in the Ford 4.0L SOHC. Replaced the left, right, and front cassettes, all were in pieces, and I replaced the tensioners. I got everything back together (finally after 6 months!). When I turn it over the motor just spins instead of the familiar "I wanna start, I wanna start" that you would expect to hear. The first time I had it back together (a couple weeks ago) I turned it over and the engine just spun like that. I came back here and read some more and realized I didn't time the cams right (had the cam slots slanted instead of parallel with the head surfaces) so I went back in and timed them again. I lined up the timing mark on the harmonic balance and then set the cams timing slots exactly parallel with the heads, off center slots lower side down.
One thing I noticed, when you rotate the crankshaft one full revolution to get back to the timing mark on the harmonic balance, the cams are upside down (off center cam slots now on the upper side). Is it possible to time this off by 180 degrees in relation to the crankshaft? If so, how can you tell which way the cams are supposed to sit?
Thanks in advance, pulling my hair out
Melch
Melch
