2004 Explorer will not start | Ford Explorer Forums
amseldon
Michigan
2004 Ford Explorer
Had a friend mechanic test battery (good) alternator (good).. Anyone else have this issue, was mentioned my "cluster" could be bad... The lights come on, gauges act a little hesitate and car won't turn over!! Please advise if you've had this happen to you!
Did you check all connectors and cables? I had a similar sounding problem and I had a positive cable that was completely corroded internally but showed o signs of it from the outside. Check that out if you haven't.
