2004 Explorer Cruise Control
There is no fuse per se for the speed control. It is controlled by the PCM thru the electronic throttle body. Will it not engage? The most common concern for that would be the deactivation switch [brake pressure 2B264 ]on the master cylinder, unplug this switch and see if it works now. If so replace the switch.
