kyturkeyhunter
- October 12, 2020
- Louisville, KY
- 2005 Explorer Limited
I've got a 2005 Limited with the 4.6 and advance track. Cruise control doesn't work at all. I bought a cruise control cut-out switch (mounts to the master cylinder) and discovered mine does not have such a switch. It instead has a Hydraulic Pressure Transducer mounted to the bottom of the master cylinder. I have not tried to replace this as I'm not sure it's related.
I replaced the brake position sensor mounted above the pedal.
I've I bought a speed sensor for the rear differential and that also isn't the issue as I couldn't find one of these mounted to the rear diff. I assume mine has sensors on each wheel in the rear and since I don't have any warning lights or codes, I assume these are fine.
I've checked every fuse in the battery compartment box and all but a couple in the steering wheel area fuse box. All fine.
I check my break lights, all work.
Recently had a mechanic fix some electrical problems that stemmed from multiple broken wires in body-door wire harness.
Things I haven't done before posting:
1. New Hydraulic Pressure Transducer. Not sure it's related and don't want to take a $100 gamble.
2. New switch on steering wheel.
Any tips? I'd love to have this creature comfort working and I'm tired of ordering parts that don't exist on my model.
