Some may have followed my previous build on my sport trac. Here is a pic and a link to the build
http://www.explorerforum.com/forums/showthread.php?t=400109.
Well im at it again with version 2.0.
specs are:
2005 Ford Explorer Sport Trac XLT
Full load with heated leather seats and moonroof
Front Suspension and Diff:
1996 Jeep cherokee High Pinion dana 30
30 spline ARB air locker (often called a super 30)
30 spline Predator Chromoly axle shaft set (equivalant in size to Dana 44)
G2 4:88 gears
3 link custom front suspension design
2" x .25" DOM links with 1.25" heim joints
Rubicon Express 7" coil springs
12" Bilstein 5125 shocks using f250 shock tower
.25" axle sleeves
Custom c knuckle gussets
Factory sport trac wheel bearing assembly (keeping factory ABS operational)
Factory sport trac brake rotors, pads, and calipers. (larger than Jeep)
Rear Suspension and Diff
Factory 8.8" disc brake rear diff
Spring over conversion keeping factory springs (for now)
11" Bilstein 5125 shocks using custom mounts
G2 4:88 Gears
ARB 31 Spline AirLocker
Steering
Toyota 4x4 steering box with 2wd pitman arm
chevy 1 ton drag link ends threaded into 1" x .25" DOM
offset chevy 1 ton tie rod ends threaded into 1" x .25" DOM
custom Freddi Link for draglink to bolt to tie rod
tie rod has been flipped ontop of steering knuckle for highsteer
modified factory steering shaft and steering lines
tracbar is 1" x .25" DOM with heim on one end and bushing on other
Draglink and tracbar are on same angle and same length for 0 bumpsteer
Transmission Crossmember
1" square tubing (eventually getting full aluminium belly skidplate)
Front Bumper
custom fabbed 1.75" tube bumper with built in winch mount
Warn VR 8000 Winch
Tires/Wheels and other goodies
35x12.5x15 BFG KM2 Tires
15x7 Ultra aluminium wheels
ARB CKMA12 air compressor
ARB tire inflation kit
JVC Double din headunit with Android App Control
Much more to come.
I have done some things slightly odd for some peoples eyes but i have done this for a reason. I plan to make this a production kit for Rangers, Explorers, and Sport tracs.
I also plan to offer a kit to use a 70`s Ford Dana 44.
I co-own an offroad shop with my Brother so this is well within our realm of things possible.
We are well known for our 4wd Van Conversions in Canada on Chevy and Ford Vans and our business has been doing this stuff since the 70`s.
specs are:
G2 4:88 gears
.25" axle sleeves
G2 4:88 Gears
Steering
Front Bumper
Warn VR 8000 Winch
Much more to come.
