rgoltsch
- April 15, 2009
- Fairfield, NJ
- 2006 Explorer XLT V8
Good morning,
We have a 2006 Explorer XLT with a V8. We just got it three weeks ago, bought it from our local Ford Dealer as a certified used vehicle.
A few times we have come back to the truck after ducking into the store and found that while the truck is all locked, the radio is on. The first time or two I figured it was a random glitch.
Now, after some testing, I found that I can reproduce the issue.
1. Drive somewhere, heck, run the motor and stop.
2. Turn off truck. Radio stays on until doors opened.
3. Exit truck, close all doors. (Radio turned off when the doors opened)
4. Lock doors via keyfob. All doors lock.
5. Press the lock button on the keyfob to make the horn beep to confirm all doors locked.
6. Stare in puzzlement as you hear relays click inside vehicle and radio comes back on. Also, if the fan to the AC was left on, the fan comes on, then turns right back off.
7. The radio stays on for about 30 minutes (I didn't exactly time it, but it was about that long). I assume the battery saver timer that turns off all inside lighting after 30 minutes overrides the ghost that turned the radio on.
Has anyone seen this issue before? I am wondering if it could be a bad door switch or something. With the certified used vehicle program from Ford, it is covered. I'd just hate to bring it in and find that it was a simple door plunger that was stuck. I did check the switches visually, but found nothing amiss.
Can anyone point me in a direction? Has anyone else heard of this? For some reason, I think I read of someone with a similar issue, but I cannot find it either here or through Google.
Thanks in advance for any help.
Ron
Ron
