sona
- July 6, 2011
- Birmingham,AL
- 2006 Eddie Bauer
I have a 2006 Explorer 4.0 Eddie Bauer with Satellite Radio. The original stereo display got damaged. I have an iSimple interface for my iphone to play through the factory radio, so I wanted to avoid getting an aftermarket unit. I opted to get another factory radio to replace my original.
I pulled this one from a 2008 Explorer at the Junkyard.
My original unit from my 2006 was:
7L2T-18C869-AC
The one I pulled from the 2008 is a:
8L2T-18C869-AG
The issue i'm having is that the new unit seems to work ok for a little while, and then resets itself. It worked great with CDs, Ipod interface, and satellite radio for the 1st day or two.
Now it's resetting more frequently.
I recorded a video of what it's doing.
<iframe width="560" height="315" src="" frameborder="0" gesture="media" allow="encrypted-media" allowfullscreen></iframe>
As you can see it starts to do a check of all the speakers (LF, LR, RF, RR) when it resets, or will just start making button selections on its own. It's weird because it seems like it's shorting out, but the when it resets, the clock is not affected, and all the presets save. I've tried it both with the factory harness and with the ipod interface harness installed - doesn't seem to make a difference.
So I've ruled out wiring as an issue.
My question is:
Is there some kind of marrying / divorcing procedure I need to follow?
Are these two units interchangeable?
I assumed they would be based on the research I've done as most of the newer units tend to be backwards compatible with older explorers.
The information only went through 2007 however, not up to 2008.
Thanks in advance for any info.
7L2T-18C869-AC
8L2T-18C869-AG
My question is:
