Boomyal
- December 28, 2013
- Vancouver, WA
- 2006 Explorer Ltd
Apparently Ford changed the head design in later 3v's and went to a one piece spark plug.
Here is a good video why the earlier ones, like mine had problems. From what I can tell, the problems were twofold. One is that the tip of the plug would grab the head and break off. The second is that you could actually strip the threads in the head while trying to turn the stuck plug out.
http://www.youtube.com/watch?v=dbauEmu9yoU
My question is, what did Ford do to change the head AND why can't you use the one piece plugs, designed for that head, in the earlier 3v's?
Also, are there any one piece plugs that you can use in the earlier 3v heads that work without fail.
Too many times, I have used plugs other than what the factory recommended and had tons of performance issues.
